Peças
Não são necessárias peças.
  1. Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face. Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
    • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
    • Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
  2. Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone. Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone. Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
    • Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Pull the flex cable connection away from the top of the phone. Pull the flex cable connection away from the top of the phone.
    • Pull the flex cable connection away from the top of the phone.
  5. Pull the camera connection away from the top of the phone. Pull the camera connection away from the top of the phone.
    • Pull the camera connection away from the top of the phone.
  6. Pull the upper metal frame away from the phone. Pull the upper metal frame away from the phone. Pull the upper metal frame away from the phone.
    • Pull the upper metal frame away from the phone.
  7. Hold the outer phone casing and pull the LCD screen out. Hold the outer phone casing and pull the LCD screen out. Hold the outer phone casing and pull the LCD screen out.
    • Hold the outer phone casing and pull the LCD screen out.
Conclusão
Will Edwards
61 reputação
9 Guides authored
Equipe
Clemson, Team 14-1, Benson Fall 2012 Membro de Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Membros
23 Guides authored
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 418
