Introdução
If you are having trouble hearing, this guide will help you replace your speaker.
O que você precisa
Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
Close the phone before proceeding.
Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
Continue to move around the phone counter clockwise until the casing is separated from the body.
After completing Steps 3-6 in the casing repair guide, your phone should look like this.
Ignoring the top logic board, take the phone in your hand and turn your attention towards the speaker.
Uma outra pessoa concluiu este guia.
