Ir para o conteúdo principal
Motorola W385 Logic Board Replacement
O que você precisa
  1. Motorola W385 Logic Board Replacement, Battery: passo 1, imagem 1 %32
    • Using your finger, press down on the clip holding the back cover on.
    Pergunte ao FixBot
    Comentar
  2. Motorola W385 Logic Board Replacement: passo 2, imagem 1 %32
    • Using the spudger or your finger, gently pull the battery out from the top.
    Pergunte ao FixBot
    Comentar
  3. Motorola W385 Logic Board Replacement, Bottom Casing: passo 3, imagem 1 %32
    • Hold the phone as shown in the photo.
    Pergunte ao FixBot
    Comentar
  4. Motorola W385 Logic Board Replacement: passo 4, imagem 1 %32 Motorola W385 Logic Board Replacement: passo 4, imagem 2 %32
    • Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
    • This might require a little persistence due how the beveled plastic rests on the phone body.
    • After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
    Pergunte ao FixBot
    Comentar
  5. Motorola W385 Logic Board Replacement: passo 5, imagem 1 %32
    • Remove the two Torx-6 screws under the removed plastic.
    Pergunte ao FixBot
    Comentar
  6. Motorola W385 Logic Board Replacement: passo 6, imagem 1 %32
    • Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Remove the four Torx-6 screws from the back plastic.
    Pergunte ao FixBot
    Comentar
  7. Motorola W385 Logic Board Replacement: passo 7, imagem 1 %32 Motorola W385 Logic Board Replacement: passo 7, imagem 2 %32 Motorola W385 Logic Board Replacement: passo 7, imagem 3 %32
    • Hold the phone with the keys facing down and the mini USB charging port visible.
    • Open the rubber flap covering the charging port.
    • Insert the flat end of the spudger just above the charging port.
    • Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
    • When working on the thinner pieces of the plastic casing, use caution insuring the plastic does not crack.
    Pergunte ao FixBot
    Comentar
  8. Motorola W385 Logic Board Replacement: passo 8, imagem 1 %32
    • The casing can be easily removed exposing the bottom logic board.
    Pergunte ao FixBot
    Comentar
  9. Motorola W385 Logic Board Replacement, Main Logic Board: passo 9, imagem 1 %32 Motorola W385 Logic Board Replacement, Main Logic Board: passo 9, imagem 2 %32
    • Use spudger to gently separate the ribbon cable from the logic board.
    Pergunte ao FixBot
    Comentar
  10. Motorola W385 Logic Board Replacement: passo 10, imagem 1 %32 Motorola W385 Logic Board Replacement: passo 10, imagem 2 %32
    • Place the sharp end of the spudger in the hole at the bottom of the logic board.
    • Gently remove the logic board from the phone casing.
    • Make sure not to damage any other components of the logic board.
    Pergunte ao FixBot
    Comentar
Conclusão
Javier Mendez
Membro desde: 01/21/10
13 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-50, Regan Winter 2010 Membro de Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Membros
Autoria de 23 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 40
Ao todo: 3,610
