Introdução
Have a faulty logic board? Replace it
Peças
Não são necessárias peças.
  1. Using your finger, press down on the clip holding the back cover on.
    • Using your finger, press down on the clip holding the back cover on.
  2. Using the spudger or your finger, gently pull the battery out from the top.
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Hold the phone as shown in the photo.
    • Hold the phone as shown in the photo.
  4. Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center. This might require a little persistence due how the beveled plastic rests on the phone body.
    • Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
    • This might require a little persistence due how the beveled plastic rests on the phone body.
    • After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
  5. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  6. Remove the two Torx-6 screws under the removed plastic.
    • Remove the two Torx-6 screws under the removed plastic.
  7. Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Remove the four Torx-6 screws from the back plastic.
  8. Hold the phone with the keys facing down and the mini USB charging port visible. Open the rubber flap covering the charging port. Insert the flat end of the spudger just above the charging port.
    • Hold the phone with the keys facing down and the mini USB charging port visible.
    • Open the rubber flap covering the charging port.
    • Insert the flat end of the spudger just above the charging port.
    • Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
    • When working on the thinner pieces of the plastic casing, use caution insuring the plastic does not crack.
  9. The casing can be easily removed exposing the bottom logic board.
    • The casing can be easily removed exposing the bottom logic board.
  10. Use spudger to gently separate the ribbon cable from the logic board. Use spudger to gently separate the ribbon cable from the logic board.
    • Use spudger to gently separate the ribbon cable from the logic board.
  11. Place the sharp end of the spudger in the hole at the bottom of the logic board. Gently remove the logic board from the phone casing.
    • Place the sharp end of the spudger in the hole at the bottom of the logic board.
    • Gently remove the logic board from the phone casing.
    • Make sure not to damage any other components of the logic board.
Conclusão
Uma outra pessoa concluiu este guia.
Javier Mendez
1 reputação
2 Guides authored
Equipe
Cal Poly, Team 8-50, Regan Winter 2010 Membro de Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Membros
14 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Todo: 3,060
