Ir para o conteúdo principal
Motorola W385 Camera Replacement
O que você precisa
  1. Motorola W385 Camera Replacement, Battery: passo 1, imagem 1 %32
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Camera Replacement: passo 2, imagem 1 %32
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Camera Replacement, Front Casing: passo 3, imagem 1 %32
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 Camera Replacement: passo 4, imagem 1 %32
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 Camera Replacement: passo 5, imagem 1 %32 Motorola W385 Camera Replacement: passo 5, imagem 2 %32
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 Camera Replacement: passo 6, imagem 1 %32
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 Camera Replacement, Top Logic Board: passo 7, imagem 1 %32
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 Camera Replacement: passo 8, imagem 1 %32 Motorola W385 Camera Replacement: passo 8, imagem 2 %32 Motorola W385 Camera Replacement: passo 8, imagem 3 %32
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 Camera Replacement: passo 9, imagem 1 %32 Motorola W385 Camera Replacement: passo 9, imagem 2 %32 Motorola W385 Camera Replacement: passo 9, imagem 3 %32
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
  10. Motorola W385 Camera Replacement, Camera: passo 10, imagem 1 %32
    • Find the camera on the board.
  11. Motorola W385 Camera Replacement: passo 11, imagem 1 %32 Motorola W385 Camera Replacement: passo 11, imagem 2 %32
    • Take your spudger and place it just under the camera as shown.
    • With a small force, the camera should remove easily.
Conclusão
Uma outra pessoa concluiu este guia.
Koedy Brant
Membro desde: 01/26/10
41 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-50, Regan Winter 2010 Membro de Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,145
