Ir para o conteúdo principal
Motorola W315 Speaker Replacement
O que você precisa
  1. Motorola W315 Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Speaker Replacement: passo 3, imagem 1 %32
    • Insert the new battery.
  3. Motorola W315 Speaker Replacement, Rear Case: passo 4, imagem 1 %32
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Speaker Replacement: passo 5, imagem 1 %32 Motorola W315 Speaker Replacement: passo 5, imagem 2 %32 Motorola W315 Speaker Replacement: passo 5, imagem 3 %32
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Speaker Replacement, Speaker: passo 6, imagem 1 %32 Motorola W315 Speaker Replacement, Speaker: passo 6, imagem 2 %32 Motorola W315 Speaker Replacement, Speaker: passo 6, imagem 3 %32
    • Using back of the plastic opening tool, push the speaker out of the casing.
    • Remove existing speaker.
    • Replace with new speaker
Conclusão
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Jacob Gray
Membro desde: 03/26/14
399 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 6-3, Benson Spring 2014 Membro de Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
Membros da 3
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 125
