Ir para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Turn off the phone.
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Insert the new battery.
    • Insert the new battery.
  3. Four 5 mm screws are visible (circled in red).
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Insert the plastic opening tool between the front and back panels of the lower half of the device. Slide the tool around the entire frame of the device until it has loosened. Remove the back of the device.
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Use the pry bar to carefully remove the headphone jack. Use the pry bar to carefully remove the headphone jack.
    • Use the pry bar to carefully remove the headphone jack.
Conclusão
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Jacob Gray
Membro desde: 26/03/2014
399 Reputação
4 Guias de autoria
Equipe
Clemson, Team 6-3, Benson Spring 2014 Membro de Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 Membros
18 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 87
