Ir para o conteúdo principal
Motorola V710 Speaker Replacement
O que você precisa
  1. Motorola V710 Speaker Replacement, Battery: passo 1, imagem 1 %32 Motorola V710 Speaker Replacement, Battery: passo 1, imagem 2 %32 Motorola V710 Speaker Replacement, Battery: passo 1, imagem 3 %32
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Speaker Replacement: passo 2, imagem 1 %32 Motorola V710 Speaker Replacement: passo 2, imagem 2 %32 Motorola V710 Speaker Replacement: passo 2, imagem 3 %32
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Speaker Replacement, Logic Board: passo 3, imagem 1 %32 Motorola V710 Speaker Replacement, Logic Board: passo 3, imagem 2 %32
    • Unscrew and remove the antenna by gripping the base and twisting clockwise.
    • Once the antenna has passed the threading, pull out.
  4. Motorola V710 Speaker Replacement: passo 4, imagem 1 %32 Motorola V710 Speaker Replacement: passo 4, imagem 2 %32
    • Remove the screws from the upper side of the phone with the T6 Torx screwdriver.
    • The first screw is underneath where the antenna was and the other is visible to the right.
  5. Motorola V710 Speaker Replacement: passo 5, imagem 1 %32 Motorola V710 Speaker Replacement: passo 5, imagem 2 %32 Motorola V710 Speaker Replacement: passo 5, imagem 3 %32
    • Insert the spudger under the left corner of the bottom plate.
    • Using a twist and pry motion seperate the bottom plate and work your way to the right.
    • This can be somewhat difficult and require a good deal of work.
  6. Motorola V710 Speaker Replacement: passo 6, imagem 1 %32 Motorola V710 Speaker Replacement: passo 6, imagem 2 %32
    • Use the T6 Torx screwdriver to remove the bottom two screws.
  7. Motorola V710 Speaker Replacement: passo 7, imagem 1 %32 Motorola V710 Speaker Replacement: passo 7, imagem 2 %32
    • Insert the spudger between the key plate and the back of the phone and work your way around the edge of the phone to pop keys off.
    • There is one clasp on either side that needs to be removed before the keys come off.
    • This step is extremely hard and may require time, strength, endurance, and multiple spudgers.
  8. Motorola V710 Speaker Replacement: passo 8, imagem 1 %32 Motorola V710 Speaker Replacement: passo 8, imagem 2 %32 Motorola V710 Speaker Replacement: passo 8, imagem 3 %32
    • Pull the pressure plate forward to expose the logic board.
    • Use the spludger to pry off the plug that connects pressure pad to the logic board.
    • Remove the pressure pad.
  9. Motorola V710 Speaker Replacement: passo 9, imagem 1 %32
    • Use the spudger to pry off the plug that connects logic board to the screen.
  10. Motorola V710 Speaker Replacement: passo 10, imagem 1 %32 Motorola V710 Speaker Replacement: passo 10, imagem 2 %32
    • Remove the logic board.
  11. Motorola V710 Speaker Replacement, Replacing Speaker: passo 11, imagem 1 %32 Motorola V710 Speaker Replacement, Replacing Speaker: passo 11, imagem 2 %32
    • Use the spudger take the speaker out.
Conclusão
Karl Sanders
Membro desde: 01/26/10
8 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 8-49, Regan Winter 2010 Membro de Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,052
