Ir para o conteúdo principal
Motorola V710 Camera Replacement
O que você precisa
  1. Motorola V710 Camera Replacement, Screen: passo 1, imagem 1 %32 Motorola V710 Camera Replacement, Screen: passo 1, imagem 2 %32 Motorola V710 Camera Replacement, Screen: passo 1, imagem 3 %32
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
    Pergunte ao FixBot
    Comentar
  2. Motorola V710 Camera Replacement: passo 2, imagem 1 %32 Motorola V710 Camera Replacement: passo 2, imagem 2 %32
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
    Pergunte ao FixBot
    Comentar
  3. Motorola V710 Camera Replacement: passo 3, imagem 1 %32 Motorola V710 Camera Replacement: passo 3, imagem 2 %32
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
    Pergunte ao FixBot
    Comentar
  4. Motorola V710 Camera Replacement: passo 4, imagem 1 %32 Motorola V710 Camera Replacement: passo 4, imagem 2 %32
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
    Pergunte ao FixBot
    Comentar
  5. Motorola V710 Camera Replacement: passo 5, imagem 1 %32 Motorola V710 Camera Replacement: passo 5, imagem 2 %32
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
    Pergunte ao FixBot
    Comentar
  6. Motorola V710 Camera Replacement: passo 6, imagem 1 %32 Motorola V710 Camera Replacement: passo 6, imagem 2 %32
    • Use the spudger to remove the screen.
    Pergunte ao FixBot
    Comentar
  7. Motorola V710 Camera Replacement, Camera: passo 7, imagem 1 %32 Motorola V710 Camera Replacement, Camera: passo 7, imagem 2 %32 Motorola V710 Camera Replacement, Camera: passo 7, imagem 3 %32
    • Use the spudger to remove the camera module.
    • Note: The camera has an adhesive holding it in place, so a slight force is necessary to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 8-49, Regan Winter 2010 Membro de Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 53
Ao todo: 1,885
