Ir para o conteúdo principal
Motorola V60s Speakers Replacement
O que você precisa
  1. Motorola V60s Speakers Replacement, Battery: passo 1, imagem 1 %32 Motorola V60s Speakers Replacement, Battery: passo 1, imagem 2 %32 Motorola V60s Speakers Replacement, Battery: passo 1, imagem 3 %32
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Speakers Replacement: passo 2, imagem 1 %32 Motorola V60s Speakers Replacement: passo 2, imagem 2 %32
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Speakers Replacement, Speakers: passo 3, imagem 1 %32 Motorola V60s Speakers Replacement, Speakers: passo 3, imagem 2 %32
    • Remove the four screws using a T6 Torx screwdriver.
    • Top screws are silver and short while bottom screws are black and longer.
  4. Motorola V60s Speakers Replacement: passo 4, imagem 1 %32 Motorola V60s Speakers Replacement: passo 4, imagem 2 %32
    • Insert an iFixit opening tool into phone in between back panel and body of phone.
    • Carefully pry up until back panel comes off, then remove with hands and set aside.
  5. Motorola V60s Speakers Replacement: passo 5, imagem 1 %32
    • Carefully insert an iFixit opening tool between the speaker and phone chassis. Slowly pry until speakers come out.
    • Be careful on this step; it may take some time.
Conclusão
Eric Freeman
Membro desde: 01/26/10
10 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 8-48, Regan Winter 2010 Membro de Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,572
