Ir para o conteúdo principal
Motorola V60s Button Key Pad Replacement
O que você precisa
  1. Motorola V60s Button Key Pad Replacement, Battery: passo 1, imagem 1 %32 Motorola V60s Button Key Pad Replacement, Battery: passo 1, imagem 2 %32 Motorola V60s Button Key Pad Replacement, Battery: passo 1, imagem 3 %32
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Button Key Pad Replacement: passo 2, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 2, imagem 2 %32
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Button Key Pad Replacement, Logic Board: passo 3, imagem 1 %32 Motorola V60s Button Key Pad Replacement, Logic Board: passo 3, imagem 2 %32
    • Unscrew four corner screws with T6 screwdriver.
    • Note: The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Button Key Pad Replacement: passo 4, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 4, imagem 2 %32 Motorola V60s Button Key Pad Replacement: passo 4, imagem 3 %32
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Button Key Pad Replacement: passo 5, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 5, imagem 2 %32 Motorola V60s Button Key Pad Replacement: passo 5, imagem 3 %32
    • Starting from left side of phone, remove side buttons and place aside.
    • Note: There should be three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Button Key Pad Replacement: passo 6, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 6, imagem 2 %32 Motorola V60s Button Key Pad Replacement: passo 6, imagem 3 %32
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Button Key Pad Replacement: passo 7, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 7, imagem 2 %32
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Note: Orange ribbon cable is fragile and can be broken.
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: passo 8, imagem 1 %32 Motorola V60s Button Key Pad Replacement, Button Key Board: passo 8, imagem 2 %32
    • Insert spudger under button board and gently lift, set aside.
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: passo 9, imagem 1 %32 Motorola V60s Button Key Pad Replacement, Button Key Pad: passo 9, imagem 2 %32
    • Life button keypad with spudger and set aside.
Conclusão
Eric Freeman
Membro desde: 01/26/10
10 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 8-48, Regan Winter 2010 Membro de Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,012
