Ir para o conteúdo principal
Motorola V60s Button Key Pad Replacement
O que você precisa
  1. Motorola V60s Button Key Pad Replacement, Battery: passo 1, imagem 1 %32 Motorola V60s Button Key Pad Replacement, Battery: passo 1, imagem 2 %32 Motorola V60s Button Key Pad Replacement, Battery: passo 1, imagem 3 %32
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
    Pergunte ao FixBot
    Comentar
  2. Motorola V60s Button Key Pad Replacement: passo 2, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 2, imagem 2 %32
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
    Pergunte ao FixBot
    Comentar
  3. Motorola V60s Button Key Pad Replacement, Motherboard: passo 3, imagem 1 %32 Motorola V60s Button Key Pad Replacement, Motherboard: passo 3, imagem 2 %32
    • Remove the four corner screws with a T6 screwdriver.
    • The two top screws are short and silver. The two bottom screws are black and long.
    Pergunte ao FixBot
    Comentar
  4. Motorola V60s Button Key Pad Replacement: passo 4, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 4, imagem 2 %32 Motorola V60s Button Key Pad Replacement: passo 4, imagem 3 %32
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
    Pergunte ao FixBot
    Comentar
  5. Motorola V60s Button Key Pad Replacement: passo 5, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 5, imagem 2 %32 Motorola V60s Button Key Pad Replacement: passo 5, imagem 3 %32
    • Starting from left side of phone, remove side buttons and place aside.
    • There are three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
    Pergunte ao FixBot
    Comentar
  6. Motorola V60s Button Key Pad Replacement: passo 6, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 6, imagem 2 %32 Motorola V60s Button Key Pad Replacement: passo 6, imagem 3 %32
    • Gently remove orange ribbon cable by prying up with spudger.
    Pergunte ao FixBot
    Comentar
  7. Motorola V60s Button Key Pad Replacement: passo 7, imagem 1 %32 Motorola V60s Button Key Pad Replacement: passo 7, imagem 2 %32
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Orange ribbon cable is fragile and can be broken.
    Pergunte ao FixBot
    Comentar
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: passo 8, imagem 1 %32 Motorola V60s Button Key Pad Replacement, Button Key Board: passo 8, imagem 2 %32
    • Insert an opening tool under the button board and gently lift.
    Pergunte ao FixBot
    Comentar
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: passo 9, imagem 1 %32 Motorola V60s Button Key Pad Replacement, Button Key Pad: passo 9, imagem 2 %32
    • Life button keypad with spudger and set aside.
    Pergunte ao FixBot
    Comentar
Conclusão
Eric Freeman
Membro desde: 01/26/10
12 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 8-48, Regan Winter 2010 Membro de Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 42
Ao todo: 3,278
