Ir para o conteúdo principal
Motorola V60s Battery Replacement
O que você precisa
  1. Motorola V60s Battery Replacement, Battery: passo 1, imagem 1 %32 Motorola V60s Battery Replacement, Battery: passo 1, imagem 2 %32 Motorola V60s Battery Replacement, Battery: passo 1, imagem 3 %32
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Battery Replacement: passo 2, imagem 1 %32 Motorola V60s Battery Replacement: passo 2, imagem 2 %32
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
Conclusão
Eric Freeman
Membro desde: 01/26/10
12 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 8-48, Regan Winter 2010 Membro de Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 82
Ao todo: 3,071
