Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Depress the silver button.
Pull from top of phone to lift the cover.
Hold battery from both sides at the bottom.
Push upwards and gently lift to remove.
Remove 4 screws from corners using T-6 screwdriver.
Use a plastic opening tool to pry up back cover from two side clips.
Use a plastic opening tool to gently remove the orange ribbon cable.
Lift up the main logic board.
NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
Carefully flip over main logic board.
Remove rubber side buttons.
