Ir para o conteúdo principal
Motorola V60c Motherboard Replacement
O que você precisa
  1. Motorola V60c Motherboard Replacement, Battery: passo 1, imagem 1 %32 Motorola V60c Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Motherboard Replacement: passo 2, imagem 1 %32 Motorola V60c Motherboard Replacement: passo 2, imagem 2 %32
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Motherboard Replacement: passo 4, imagem 1 %32 Motorola V60c Motherboard Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to pry up back cover from the two side clips.
    • NOTE: sticker might be attached to rest of phone.
  5. Motorola V60c Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the back cover.
  6. Motorola V60c Motherboard Replacement: passo 6, imagem 1 %32 Motorola V60c Motherboard Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board to remove.
Conclusão
Ryan Kuroiwa
Membro desde: 04/10/10
1 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 25-86, Amido Spring 2010 Membro de Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 2,350
