Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Depress the silver button.
Pull from top of phone to lift the cover.
Hold battery from both sides at the bottom.
Push upwards and gently lift to remove.
Remove 4 screws from corners using T-6 screwdriver.
NOTE: Make sure screws return to correct place when reassembling.
Use a plastic opening tool to pry up back cover from the two side clips.
Use a plastic opening tool to gently remove the orange ribbon cable.
Lift up the main logic board to remove.
