Ir para o conteúdo principal
Motorola V60c Keypad and Keypad Logic Board Replacement
O que você precisa
  1. Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: passo 1, imagem 1 %32 Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: passo 1, imagem 2 %32
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 2, imagem 1 %32 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 2, imagem 2 %32
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Keypad and Keypad Logic Board Replacement, Keypad and Keypad Logic Board: passo 3, imagem 1 %32
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 4, imagem 1 %32 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 4, imagem 2 %32
    • Use plastic opening tool to pry up back cover from two side clips.
    • NOTE: Sticker might be attached to rest of phone.
  5. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 5, imagem 1 %32
    • Remove the back cover.
  6. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 6, imagem 1 %32 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board.
    • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
  7. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 7, imagem 1 %32 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 7, imagem 2 %32
    • Remove the keypad logic board.
    • NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
  8. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 8, imagem 1 %32 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 8, imagem 2 %32 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 8, imagem 3 %32
    • Remove the keypad.
Conclusão
Ryan Kuroiwa
Membro desde: 04/10/10
1 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 25-86, Amido Spring 2010 Membro de Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 2,143
