Ir para o conteúdo principal
Motorola V557 Screen Replacement
O que você precisa
  1. Motorola V557 Screen Replacement, Faceplate: passo 1, imagem 1 %32 Motorola V557 Screen Replacement, Faceplate: passo 1, imagem 2 %32 Motorola V557 Screen Replacement, Faceplate: passo 1, imagem 3 %32
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  2. Motorola V557 Screen Replacement: passo 2, imagem 1 %32 Motorola V557 Screen Replacement: passo 2, imagem 2 %32
    • Remove the four 3.8 mm T-6 Torx screws.
  3. Motorola V557 Screen Replacement: passo 3, imagem 1 %32 Motorola V557 Screen Replacement: passo 3, imagem 2 %32
    • Separate the cover from the edges using a plastic opening tool.
  4. Motorola V557 Screen Replacement: passo 4, imagem 1 %32 Motorola V557 Screen Replacement: passo 4, imagem 2 %32
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
  5. Motorola V557 Screen Replacement, Camera: passo 5, imagem 1 %32
    • Gently peel off the plastic film from the metal plate above the camera lens as shown.
  6. Motorola V557 Screen Replacement: passo 6, imagem 1 %32 Motorola V557 Screen Replacement: passo 6, imagem 2 %32
    • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
    • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
  7. Motorola V557 Screen Replacement: passo 7, imagem 1 %32 Motorola V557 Screen Replacement: passo 7, imagem 2 %32
    • Lift and peel back the tape attaching metal casing to body of the phone.
    • Gently lift the metal cover and remove to expose the circuit board.
  8. Motorola V557 Screen Replacement: passo 8, imagem 1 %32 Motorola V557 Screen Replacement: passo 8, imagem 2 %32
    • Using a plastic opening tool, pry or lift open the pink door shown.
    • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
  9. Motorola V557 Screen Replacement: passo 9, imagem 1 %32 Motorola V557 Screen Replacement: passo 9, imagem 2 %32 Motorola V557 Screen Replacement: passo 9, imagem 3 %32
    • Use a plastic opening tool to dislodge and remove the rubber camera cover.
  10. Motorola V557 Screen Replacement: passo 10, imagem 1 %32 Motorola V557 Screen Replacement: passo 10, imagem 2 %32
    • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
  11. Motorola V557 Screen Replacement, Screen: passo 11, imagem 1 %32 Motorola V557 Screen Replacement, Screen: passo 11, imagem 2 %32 Motorola V557 Screen Replacement, Screen: passo 11, imagem 3 %32
    • Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
    • Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
Conclusão
Blair Frandeen
Membro desde: 10/02/10
19 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-50, Amido Fall 2010 Membro de Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
Membros da 4
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 2,753
