Ir para o conteúdo principal
Motorola V557 Headphone Jack Replacement
O que você precisa
  1. Motorola V557 Headphone Jack Replacement, Battery: passo 1, imagem 1 %32 Motorola V557 Headphone Jack Replacement, Battery: passo 1, imagem 2 %32 Motorola V557 Headphone Jack Replacement, Battery: passo 1, imagem 3 %32
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Headphone Jack Replacement: passo 2, imagem 1 %32 Motorola V557 Headphone Jack Replacement: passo 2, imagem 2 %32
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Headphone Jack Replacement, SIM Card: passo 3, imagem 1 %32 Motorola V557 Headphone Jack Replacement, SIM Card: passo 3, imagem 2 %32 Motorola V557 Headphone Jack Replacement, SIM Card: passo 3, imagem 3 %32
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Headphone Jack Replacement, Antenna: passo 4, imagem 1 %32 Motorola V557 Headphone Jack Replacement, Antenna: passo 4, imagem 2 %32
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Headphone Jack Replacement, Rear Casing: passo 5, imagem 1 %32 Motorola V557 Headphone Jack Replacement, Rear Casing: passo 5, imagem 2 %32 Motorola V557 Headphone Jack Replacement, Rear Casing: passo 5, imagem 3 %32
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 Headphone Jack Replacement: passo 6, imagem 1 %32 Motorola V557 Headphone Jack Replacement: passo 6, imagem 2 %32 Motorola V557 Headphone Jack Replacement: passo 6, imagem 3 %32
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 Headphone Jack Replacement: passo 7, imagem 1 %32 Motorola V557 Headphone Jack Replacement: passo 7, imagem 2 %32 Motorola V557 Headphone Jack Replacement: passo 7, imagem 3 %32
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
  8. Motorola V557 Headphone Jack Replacement, Headphone Jack: passo 8, imagem 1 %32 Motorola V557 Headphone Jack Replacement, Headphone Jack: passo 8, imagem 2 %32 Motorola V557 Headphone Jack Replacement, Headphone Jack: passo 8, imagem 3 %32
    • Lastly, using a push pin, lift out and to the left to release the headphone jack assembly.
    • Insert the new headphone jack assembly and repeat these steps in reverse order.
Conclusão
Alex Georges
Membro desde: 10/02/10
40 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-50, Amido Fall 2010 Membro de Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
Membros da 4
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,653
