Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Ferramenta utilizada nesse passo:Spudger$3.99-
On the phone's face, remove the four rubber caps from the screw covers using a spudger.
Unscrew the four cover screws using a T6 Torx screwdriver, turning counterclockwise.
Loosen and remove the protective cover using a plastic opening tool.
Gently loosen the second protective cover with the plastic opening tool.
Carefully remove the protective cover from the circuitry.
Slowly peel the black rubber gasket off of the circuit board.
Carefully move the camera out of the way using your hand.
Use a flat tool to disconnect the upper and lower circuit boards.
Gently slip the copper strip out from under the circuitry by using your hand.
