Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This is a guide showing how to replace and repair the keypad of the phone.
O que você precisa
Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
Remove the rubber screw covers using a plastic spudger.
Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
Push both side keys in so they are not sticking out of the phone.
Remove the keypad.
