Ir para o conteúdo principal
Motorola V551 Keypad Key Replacement
O que você precisa
  1. Motorola V551 Keypad Key Replacement, Battery: passo 1, imagem 1 %32 Motorola V551 Keypad Key Replacement, Battery: passo 1, imagem 2 %32
    • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
  2. Motorola V551 Keypad Key Replacement: passo 2, imagem 1 %32
    • Lever the battery out by pressing upwards on the bottom corners of the battery.
  3. Motorola V551 Keypad Key Replacement, Circuit Board: passo 3, imagem 1 %32 Motorola V551 Keypad Key Replacement, Circuit Board: passo 3, imagem 2 %32 Motorola V551 Keypad Key Replacement, Circuit Board: passo 3, imagem 3 %32
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
  4. Motorola V551 Keypad Key Replacement: passo 4, imagem 1 %32
    • Unscrew the antenna.
  5. Motorola V551 Keypad Key Replacement: passo 5, imagem 1 %32 Motorola V551 Keypad Key Replacement: passo 5, imagem 2 %32 Motorola V551 Keypad Key Replacement: passo 5, imagem 3 %32
    • Gently release the two latches using an opening tool.
    • The plastic latches are very fragile. Don’t use excessive force or they might break.
    • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
    • Lift the back panel off of the phone.
  6. Motorola V551 Keypad Key Replacement: passo 6, imagem 1 %32 Motorola V551 Keypad Key Replacement: passo 6, imagem 2 %32
    • Loosen the copper circuit board connection with an opening tool.
    • Gently lift the copper connection.
  7. Motorola V551 Keypad Key Replacement: passo 7, imagem 1 %32 Motorola V551 Keypad Key Replacement: passo 7, imagem 2 %32 Motorola V551 Keypad Key Replacement: passo 7, imagem 3 %32
    • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
    • Gently lift the motherboard off of the front panel.
  8. Motorola V551 Keypad Key Replacement, Keypad: passo 8, imagem 1 %32 Motorola V551 Keypad Key Replacement, Keypad: passo 8, imagem 2 %32 Motorola V551 Keypad Key Replacement, Keypad: passo 8, imagem 3 %32
    • Push both side keys in so they are not sticking out of the phone.
    • Remove the keypad.
  9. Motorola V551 Keypad Key Replacement, Keypad Key: passo 9, imagem 1 %32 Motorola V551 Keypad Key Replacement, Keypad Key: passo 9, imagem 2 %32
    • Gently squeeze the bottle of super glue so that only a small amount (about 1/3 pinky width) is a applied to the back side of the key.
    • Be careful while applying the super glue as it can be quite strong.
  10. Motorola V551 Keypad Key Replacement: passo 10, imagem 1 %32 Motorola V551 Keypad Key Replacement: passo 10, imagem 2 %32
    • Carefully place key onto the key pad so that it will be properly oriented and in line with the other keys.
Conclusão
Uma outra pessoa concluiu este guia.
gregatron
Membro desde: 10/29/09
105 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 6-6, Maness Fall 2009 Membro de Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,936
