Ir para o conteúdo principal
Motorola V276 Speaker Replacement
O que você precisa
  1. Motorola V276 Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Speaker Replacement: passo 2, imagem 1 %32
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Speaker Replacement: passo 3, imagem 1 %32 Motorola V276 Speaker Replacement: passo 3, imagem 2 %32
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Speaker Replacement, Speaker: passo 4, imagem 1 %32
    • Use Spudger to remove rubber plug from upper left corner of the back of the phone
  5. Motorola V276 Speaker Replacement: passo 5, imagem 1 %32
    • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
  6. Motorola V276 Speaker Replacement: passo 6, imagem 1 %32 Motorola V276 Speaker Replacement: passo 6, imagem 2 %32 Motorola V276 Speaker Replacement: passo 6, imagem 3 %32
    • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Speaker Replacement: passo 7, imagem 1 %32 Motorola V276 Speaker Replacement: passo 7, imagem 2 %32
    • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
  8. Motorola V276 Speaker Replacement: passo 8, imagem 1 %32 Motorola V276 Speaker Replacement: passo 8, imagem 2 %32
    • Using tweezers or your hands, pick out the semicircular plastic border between the speaker and headphone jack
  9. Motorola V276 Speaker Replacement: passo 9, imagem 1 %32
    • Using a spudger, remove the speaker
Conclusão
Kyle Klitzner
Membro desde: 04/11/10
1 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 27-96, Amido Spring 2010 Membro de Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 9
Duração total: 1,013
