Ir para o conteúdo principal
Motorola V276 Battery Replacement
O que você precisa
  1. Motorola V276 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Battery Replacement: passo 2, imagem 1 %32
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Battery Replacement: passo 3, imagem 1 %32 Motorola V276 Battery Replacement: passo 3, imagem 2 %32
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
Conclusão
Jason Kilroy
Membro desde: 04/11/10
1 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 27-96, Amido Spring 2010 Membro de Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,652
