Ir para o conteúdo principal
Motorola V2397 Motherboard/Screen Replacement
O que você precisa
  1. Motorola V2397 Motherboard/Screen Replacement, Battery: passo 1, imagem 1 %32 Motorola V2397 Motherboard/Screen Replacement, Battery: passo 1, imagem 2 %32 Motorola V2397 Motherboard/Screen Replacement, Battery: passo 1, imagem 3 %32
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Motherboard/Screen Replacement: passo 2, imagem 1 %32 Motorola V2397 Motherboard/Screen Replacement: passo 2, imagem 2 %32
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Motherboard/Screen Replacement, Back Cover: passo 3, imagem 1 %32 Motorola V2397 Motherboard/Screen Replacement, Back Cover: passo 3, imagem 2 %32
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Motherboard/Screen Replacement: passo 4, imagem 1 %32 Motorola V2397 Motherboard/Screen Replacement: passo 4, imagem 2 %32
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Motherboard/Screen Replacement, Phone: passo 5, imagem 1 %32 Motorola V2397 Motherboard/Screen Replacement, Phone: passo 5, imagem 2 %32
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  6. Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: passo 6, imagem 1 %32 Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: passo 6, imagem 2 %32
    • Use your fingers to unhook the highlighted plastic frame of the screen from motherboard
    • Carefully separate the screen from the motherboard
    • Note the cable connecting the screen to the motherboard. Do not pull the screen too far from the motherboard or you may damage the cable
  7. Motorola V2397 Motherboard/Screen Replacement: passo 7, imagem 1 %32 Motorola V2397 Motherboard/Screen Replacement: passo 7, imagem 2 %32
    • Lift the flap of the connector on the motherboard using a spudger
    • Carefully remove the FFC cable from the connector
    • The screen should now be free from the motherboard
Conclusão
Chris
Membro desde: 01/13/15
501 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-6, Sullivan Winter 2015 Membro de USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 147
