Ir para o conteúdo principal
Motorola V2397 Front Cover Replacement
O que você precisa
  1. Motorola V2397 Front Cover Replacement, Battery: passo 1, imagem 1 %32 Motorola V2397 Front Cover Replacement, Battery: passo 1, imagem 2 %32 Motorola V2397 Front Cover Replacement, Battery: passo 1, imagem 3 %32
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Front Cover Replacement: passo 2, imagem 1 %32 Motorola V2397 Front Cover Replacement: passo 2, imagem 2 %32
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Front Cover Replacement, Back Cover: passo 3, imagem 1 %32 Motorola V2397 Front Cover Replacement, Back Cover: passo 3, imagem 2 %32
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Front Cover Replacement: passo 4, imagem 1 %32 Motorola V2397 Front Cover Replacement: passo 4, imagem 2 %32
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Front Cover Replacement, Side Buttons: passo 5, imagem 1 %32 Motorola V2397 Front Cover Replacement, Side Buttons: passo 5, imagem 2 %32
    • Lift and remove buttons by hand
  6. Motorola V2397 Front Cover Replacement, Phone: passo 6, imagem 1 %32 Motorola V2397 Front Cover Replacement, Phone: passo 6, imagem 2 %32
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  7. Motorola V2397 Front Cover Replacement, Keypad: passo 7, imagem 1 %32 Motorola V2397 Front Cover Replacement, Keypad: passo 7, imagem 2 %32 Motorola V2397 Front Cover Replacement, Keypad: passo 7, imagem 3 %32
    • Grip the top of the rubber keypad with your thumb and index finger
    • While holding the keypad start to peel it back from the front cover until the keypad is completely detached
  8. Motorola V2397 Front Cover Replacement, Speaker: passo 8, imagem 1 %32 Motorola V2397 Front Cover Replacement, Speaker: passo 8, imagem 2 %32
    • Use the iFixit opening tool to lift the speaker off the front cover.
  9. Motorola V2397 Front Cover Replacement, Front Cover: passo 9, imagem 1 %32 Motorola V2397 Front Cover Replacement, Front Cover: passo 9, imagem 2 %32
    • Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself
Conclusão
Connor
Membro desde: 01/13/15
201 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-6, Sullivan Winter 2015 Membro de USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 109
