Ir para o conteúdo principal
Motorola V190 Keypad Replacement
O que você precisa
  1. Motorola V190 Keypad Replacement, Antenna: passo 1, imagem 1 %32 Motorola V190 Keypad Replacement, Antenna: passo 1, imagem 2 %32
    • Rotate the antenna counter-clockwise until the antenna is completely removed.
    Pergunte ao FixBot
    Comentar
  2. Motorola V190 Keypad Replacement, Battery: passo 2, imagem 1 %32 Motorola V190 Keypad Replacement, Battery: passo 2, imagem 2 %32
    • Press the button at the bottom of the back cover.
    • Pull the back cover down.
    • Remove the battery.
    • Our device is missing the battery.
    Pergunte ao FixBot
    Comentar
  3. Motorola V190 Keypad Replacement, Mini-USB Port/Motherboard: passo 3, imagem 1 %32
    • Use the TR6 Torx Security Screwdriver to remove the four 6.3mm Torx screws on the back.
    Pergunte ao FixBot
    Comentar
  4. Motorola V190 Keypad Replacement: passo 4, imagem 1 %32 Motorola V190 Keypad Replacement: passo 4, imagem 2 %32 Motorola V190 Keypad Replacement: passo 4, imagem 3 %32
    • Use the iFixit opening tool to pry open the crevice at the top of phone.
    • Use the same tool to pry open the crevice at the bottom of the phone.
    • At this time, do not separate the ribbon from the motherboard at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  5. Motorola V190 Keypad Replacement: passo 5, imagem 1 %32 Motorola V190 Keypad Replacement: passo 5, imagem 2 %32 Motorola V190 Keypad Replacement: passo 5, imagem 3 %32
    • Remove the black rubber piece from the top of the motherboard.
    • Disconnect the rectangular ribbon from the motherboard.
    • Remove the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Motorola V190 Keypad Replacement, Keypad: passo 6, imagem 1 %32 Motorola V190 Keypad Replacement, Keypad: passo 6, imagem 2 %32 Motorola V190 Keypad Replacement, Keypad: passo 6, imagem 3 %32
    • Reopen the phone.
    • Press the push buttons (the volume buttons) through the phone frame to fully remove the keypad.
    • Push the keypad through the keypad frame.
    • Remove the keypad by lifting it over the screw holes.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 42
Ao todo: 505
