Ir para o conteúdo principal
Motorola V180 Motherboard Replacement
O que você precisa
  1. Motorola V180 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Motorola V180 Motherboard Replacement, Battery: passo 1, imagem 2 %32 Motorola V180 Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: passo 2, imagem 1 %32 Motorola V180 Motherboard Replacement, Motherboard: passo 2, imagem 2 %32 Motorola V180 Motherboard Replacement, Motherboard: passo 2, imagem 3 %32
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  3. Motorola V180 Motherboard Replacement: passo 3, imagem 1 %32 Motorola V180 Motherboard Replacement: passo 3, imagem 2 %32
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard by lifting it up out of the keypad.
Conclusão
Tyler Knisley
Membro desde: 05/07/10
1 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 6-16, Maness Spring 2010 Membro de Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 1,839
