Introdução
The two way radio speaker is responsible for broadcasting the signal received, making it a very important part. Follow the steps below to properly replace the speaker of the radio.
O que você precisa
Remove the four 3 millimeter T6 Torx screws from the front of the radio.
To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push.
The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
Gostaria de saber se eu tenho como encontrar a placa para fazer a troca, tenho um rádio da Motorola t400
mauropessoa - Responder
