Pular para o conteúdo principal
  1. Push down on the black tab located at the top center of the Motorola phone
    • Push down on the black tab located at the top center of the Motorola phone
  2. Remove the battery by pulling the battery from the top center.
    • Remove the battery by pulling the battery from the top center.
  3. Remove the four T6 2 mm TX Torx screws
    • Remove the four T6 2 mm TX Torx screws
  4. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  5. Insert the flat end of a plastic opening tool and pry the metal cover up off the phone. Insert the flat end of a plastic opening tool and pry the metal cover up off the phone.
    • Insert the flat end of a plastic opening tool and pry the metal cover up off the phone.
  6. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a plastic opening tool. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a plastic opening tool.
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a plastic opening tool.
  7. Use a plastic opening tool to pry the antenna cable connectors from its respective socket on the motherboard.
    • Use a plastic opening tool to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
  8. Use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • Use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • The cover is attached by adhesive, so some force may be required.
  9. Insert the flat end of a spudger and pry the frame off the phone. The frame is attached by adhesive, so some force may be required
    • Insert the flat end of a spudger and pry the frame off the phone.
    • The frame is attached by adhesive, so some force may be required
Conclusão
2 outras pessoas concluíram este guia.
Jorge Trujillo
Membro desde: 19-05-2011
499 reputação
4 Guias de autoria
Equipe
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Todo: 2,669
