Ir para o conteúdo principal
Motorola SLVR L9 Keypad Replacement
O que você precisa
  1. Motorola SLVR L9 Keypad Replacement, Battery: passo 1, imagem 1 %32 Motorola SLVR L9 Keypad Replacement, Battery: passo 1, imagem 2 %32
    • Turn the phone over so that the back of the phone is facing up.
    Pergunte ao FixBot
    Comentar
  2. Motorola SLVR L9 Keypad Replacement: passo 2, imagem 1 %32 Motorola SLVR L9 Keypad Replacement: passo 2, imagem 2 %32 Motorola SLVR L9 Keypad Replacement: passo 2, imagem 3 %32
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
    Pergunte ao FixBot
    Comentar
  3. Motorola SLVR L9 Keypad Replacement: passo 3, imagem 1 %32 Motorola SLVR L9 Keypad Replacement: passo 3, imagem 2 %32 Motorola SLVR L9 Keypad Replacement: passo 3, imagem 3 %32
    • To remove the battery, pull the battery up from the bottom center.
    Pergunte ao FixBot
    Comentar
  4. Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: passo 4, imagem 1 %32 Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: passo 4, imagem 2 %32
    • Turn the phone over so that the back of the phone is facing towards you.
    Pergunte ao FixBot
    Comentar
  5. Motorola SLVR L9 Keypad Replacement: passo 5, imagem 1 %32 Motorola SLVR L9 Keypad Replacement: passo 5, imagem 2 %32 Motorola SLVR L9 Keypad Replacement: passo 5, imagem 3 %32
    • Press down on the battery cover latch located at the top of the phone.
    Pergunte ao FixBot
    Comentar
  6. Motorola SLVR L9 Keypad Replacement: passo 6, imagem 1 %32
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
    Pergunte ao FixBot
    Comentar
  7. Motorola SLVR L9 Keypad Replacement: passo 7, imagem 1 %32 Motorola SLVR L9 Keypad Replacement: passo 7, imagem 2 %32
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
    Pergunte ao FixBot
    Comentar
  8. Motorola SLVR L9 Keypad Replacement, Antenna Cover: passo 8, imagem 1 %32 Motorola SLVR L9 Keypad Replacement, Antenna Cover: passo 8, imagem 2 %32 Motorola SLVR L9 Keypad Replacement, Antenna Cover: passo 8, imagem 3 %32
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
    Pergunte ao FixBot
    Comentar
  9. Motorola SLVR L9 Keypad Replacement, Keypad: passo 9, imagem 1 %32
    • Use a screwdriver with a T6 Torx screwdriver head to remove both screws (1/8") from the speaker housing. Turn the screw counter-clockwise (left).
    Pergunte ao FixBot
    Comentar
  10. Motorola SLVR L9 Keypad Replacement: passo 10, imagem 1 %32 Motorola SLVR L9 Keypad Replacement: passo 10, imagem 2 %32 Motorola SLVR L9 Keypad Replacement: passo 10, imagem 3 %32
    • Using the grooves around the edge of the phone, gently pull the front plate away from the phone until it is fully removed from the device.
    Pergunte ao FixBot
    Comentar
  11. Motorola SLVR L9 Keypad Replacement: passo 11, imagem 1 %32 Motorola SLVR L9 Keypad Replacement: passo 11, imagem 2 %32
    • Lift the keypad up from the front plate to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
Eric Lopez
Membro desde: 10/13/15
201 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 569
