Introdução
The Antenna Cover Guide provides a list of the tools and parts that you need to replace the antenna cover on the Motorola SLVR L9. As you begin the replacement process, look for the pictures provided with each step to better guide you.
O que você precisa
Use the plastic opening tool to loosen the cover latch.
Once the cover latch has been loosened, gently pull the cover latch off of the device.
Quase terminado!
Conclusão
