Introdução
This guide will show you how to remove and replace the speaker for a Motorola V3c.
Peças
Não são necessárias peças.
  1. Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    • Unscrew the two screws in the back using the T6.
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
    • Peel off the connector between the motherboard and the body of the phone.
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
    • Pull out the speaker.
Conclusão
Joshua Ruehlig
503 reputação
4 Guides authored
Equipe
Cal Poly, Team 11-4, Forte Winter 2010 Membro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Membros
8 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Todo: 5,278
