Ir para o conteúdo principal
Motorola Razr V3c Motherboard (CDMA) Replacement
O que você precisa
  1. Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): passo 1, imagem 1 %32 Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): passo 1, imagem 2 %32 Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): passo 1, imagem 3 %32
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Motherboard (CDMA) Replacement: passo 2, imagem 1 %32 Motorola Razr V3c Motherboard (CDMA) Replacement: passo 2, imagem 2 %32
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Motherboard (CDMA) Replacement, Speaker (CDMA): passo 3, imagem 1 %32
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Motherboard (CDMA) Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Motherboard (CDMA) Replacement: passo 5, imagem 1 %32
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Motherboard (CDMA) Replacement: passo 6, imagem 1 %32 Motorola Razr V3c Motherboard (CDMA) Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Motherboard (CDMA) Replacement: passo 7, imagem 1 %32 Motorola Razr V3c Motherboard (CDMA) Replacement: passo 7, imagem 2 %32
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Motherboard (CDMA) Replacement: passo 8, imagem 1 %32
    • Pull out the speaker.
  9. Motorola Razr V3c Motherboard (CDMA) Replacement, Motherboard (CDMA): passo 9, imagem 1 %32 Motorola Razr V3c Motherboard (CDMA) Replacement, Motherboard (CDMA): passo 9, imagem 2 %32
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
Conclusão
6 outras pessoas executaram este guia.
Joshua Ruehlig
Membro desde: 01/14/10
506 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 11-4, Forte Winter 2010 Membro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 6,707
