Ir para o conteúdo principal
Motorola Razr V3c Keypad Cover (CDMA) Replacement
O que você precisa
  1. Motorola Razr V3c Keypad Cover (CDMA) Replacement, Battery (CDMA): passo 1, imagem 1 %32 Motorola Razr V3c Keypad Cover (CDMA) Replacement, Battery (CDMA): passo 1, imagem 2 %32 Motorola Razr V3c Keypad Cover (CDMA) Replacement, Battery (CDMA): passo 1, imagem 3 %32
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Keypad Cover (CDMA) Replacement: passo 2, imagem 1 %32 Motorola Razr V3c Keypad Cover (CDMA) Replacement: passo 2, imagem 2 %32
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Keypad Cover (CDMA) Replacement, Keypad Cover (CDMA): passo 3, imagem 1 %32
    • Remove the two T6 screws on the back of the phone.
  4. Motorola Razr V3c Keypad Cover (CDMA) Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to pop the bottom part of the back case out.
    • The back case is connected to the phone with a ribbon cable; take care not to pull too hard or violently on the cable.
  5. Motorola Razr V3c Keypad Cover (CDMA) Replacement: passo 5, imagem 1 %32
    • Gently pull back case out and lay it over to the side.
    • Now pull up on the cable attaching the back case to the phone body to separate the two parts. Lay the back case aside for now.
  6. Motorola Razr V3c Keypad Cover (CDMA) Replacement: passo 6, imagem 1 %32
    • Remove the two T6 screws securing the plastic speaker cover to the phone.
  7. Motorola Razr V3c Keypad Cover (CDMA) Replacement: passo 7, imagem 1 %32
    • Pull off the lower front casing.
    • The metal shield will come off when the lower front casing is removed. Make sure to replace this when reassembling the lower bottom casing.
  8. Motorola Razr V3c Keypad Cover (CDMA) Replacement: passo 8, imagem 1 %32
    • Pull the silver plastic cover down away from the rest of the phone.
  9. Motorola Razr V3c Keypad Cover (CDMA) Replacement: passo 9, imagem 1 %32
    • Push the metal tabs along the perimeter of the device through towards the keyboard with your fingers.
  10. Motorola Razr V3c Keypad Cover (CDMA) Replacement: passo 10, imagem 1 %32
    • Gently lift up on the keypad with the plastic opening tool while being careful not to bend the thin metal portion lining the keypad.
Conclusão
krisko
Membro desde: 01/14/10
104 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 11-4, Forte Winter 2010 Membro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 15
Duração total: 7,076
