Ir para o conteúdo principal
Motorola Razr V3c Camera (CDMA) Replacement
O que você precisa
  1. Motorola Razr V3c Camera (CDMA) Replacement, Upper Casing (CDMA): passo 1, imagem 1 %32
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Motorola Razr V3c Camera (CDMA) Replacement: passo 2, imagem 1 %32
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
  3. Motorola Razr V3c Camera (CDMA) Replacement: passo 3, imagem 1 %32
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  4. Motorola Razr V3c Camera (CDMA) Replacement: passo 4, imagem 1 %32 Motorola Razr V3c Camera (CDMA) Replacement: passo 4, imagem 2 %32 Motorola Razr V3c Camera (CDMA) Replacement: passo 4, imagem 3 %32
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  5. Motorola Razr V3c Camera (CDMA) Replacement, Camera (CDMA): passo 5, imagem 1 %32 Motorola Razr V3c Camera (CDMA) Replacement, Camera (CDMA): passo 5, imagem 2 %32
    • Pry screen cover off with plastic opening tool.
    • The screen cover has some adhesive holding it to the screen.
  6. Motorola Razr V3c Camera (CDMA) Replacement: passo 6, imagem 1 %32
    • Remove small black sticker covering the camera ribbon connector.
  7. Motorola Razr V3c Camera (CDMA) Replacement: passo 7, imagem 1 %32
    • Flip over small hinge that covers the camera ribbon connection.
  8. Motorola Razr V3c Camera (CDMA) Replacement: passo 8, imagem 1 %32 Motorola Razr V3c Camera (CDMA) Replacement: passo 8, imagem 2 %32 Motorola Razr V3c Camera (CDMA) Replacement: passo 8, imagem 3 %32
    • Pull off the rubber camera cover and camera.
    • The camera and camera cover may come off either separately or together.
Linha de Chegada
Joshua Ruehlig
Membro desde: 01/14/10
506 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 11-4, Forte Winter 2010 Membro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 4,543
