Ir para o conteúdo principal
Motorola Razr V3 Antenna Replacement
O que você precisa
  1. Motorola Razr V3 Antenna Replacement, Battery: passo 1, imagem 1 %32 Motorola Razr V3 Antenna Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Antenna Replacement: passo 2, imagem 1 %32 Motorola Razr V3 Antenna Replacement: passo 2, imagem 2 %32
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Antenna Replacement, Antenna: passo 3, imagem 1 %32
    • Unscrew the two 5mm T6 Torx screws form the phone.
  4. Motorola Razr V3 Antenna Replacement: passo 4, imagem 1 %32
    • Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
    • You can rotate the phone left and right to get easier access while prying.
    • Make sure to fold back of phone down (or left depending on your orientation) after separating from body as there is ribbon connecting the back to the phone's body which can be ripped if pulled the wrong way.
    • The tab as well as the plastic clips are fragile, be careful when using them.
  5. Motorola Razr V3 Antenna Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
    • The clear part below the circuit board is the antenna.
  6. Motorola Razr V3 Antenna Replacement: passo 6, imagem 1 %32
    • Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
    • These clips are also fragile.
    • When reassembling, make sure the copper piece of the antenna is properly inserted between the two copper clips that stick up from the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Ross Byers
Membro desde: 04/18/13
279 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-46, Amido Spring 2013 Membro de Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 Membros
Autoria de 10 guias
1Comentário do guia
Elok tenan Jan sing posting
Haryanto - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 3,957
