Ir para o conteúdo principal
Motorola RIZR Z3 Motherboard Replacement
O que você precisa
  1. Motorola RIZR Z3 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Motorola RIZR Z3 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 Motherboard Replacement: passo 2, imagem 1 %32 Motorola RIZR Z3 Motherboard Replacement: passo 2, imagem 2 %32
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 Motherboard Replacement: passo 4, imagem 1 %32 Motorola RIZR Z3 Motherboard Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 Motherboard Replacement: passo 5, imagem 1 %32
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 Motherboard Replacement: passo 6, imagem 1 %32 Motorola RIZR Z3 Motherboard Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 Motherboard Replacement: passo 7, imagem 1 %32 Motorola RIZR Z3 Motherboard Replacement: passo 7, imagem 2 %32
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 Motherboard Replacement: passo 8, imagem 1 %32 Motorola RIZR Z3 Motherboard Replacement: passo 8, imagem 2 %32
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
Conclusão
Andrew Brock
Membro desde: 10/07/11
8 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-34, Amido Fall 2011 Membro de Cal Poly, Team 5-34, Amido Fall 2011
CPSU-AMIDO-F11S5G34
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,320
