Introdução
Use this guide to remove and install a keypad in a Motorola RAZR2 v9m. Also works for other RAZR2 v8 and RAZR v9 models.
O que você precisa
Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
Flip the RAZR2 open with the battery compartment facing you.
Pull the white battery tab away from the phone to reveal a small black gap in the battery compartment.
Place the spudger into this gap. Rest the spudger against the black plastic inside of the gap.
