Ir para o conteúdo principal
Motorola RAZR V3i Battery Replacement
O que você precisa
  1. Motorola RAZR V3i Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: passo 2, imagem 1 %32 Motorola RAZR V3i Battery Replacement: passo 2, imagem 2 %32 Motorola RAZR V3i Battery Replacement: passo 2, imagem 3 %32
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: passo 3, imagem 1 %32 Motorola RAZR V3i Battery Replacement: passo 3, imagem 2 %32 Motorola RAZR V3i Battery Replacement: passo 3, imagem 3 %32
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
Linha de Chegada
5 outras pessoas executaram este guia.
Nigel
Membro desde: 09/06/11
133 Reputação
Autoria de 2 guias
Equipe
Cuesta, Team 1-5, Zipperian Fall 2011 Membro de Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 Membro
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 49
Duração total: 7,186
