Introdução
Removal of the motherboard is necessary to access the rear facing camera. This guide involves the removal of various screws and parts so make sure you are in a clean and organized environment to avoid the loss of any components.
O que você precisa
Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
Using a T5 Torx screwdriver, unscrew the two 4.0mm screws on the rear-facing camera cover.
