Ir para o conteúdo principal
Motorola Q Global Camera Replacement
O que você precisa
  1. Motorola Q Global Camera Replacement, Battery: passo 1, imagem 1 %32
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Camera Replacement: passo 2, imagem 1 %32 Motorola Q Global Camera Replacement: passo 2, imagem 2 %32
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Camera Replacement, Camera: passo 3, imagem 1 %32
    • Press inward on the upper casing.
  4. Motorola Q Global Camera Replacement: passo 4, imagem 1 %32
    • Slide the upper case to the right and lift up.
    • Lift the camera sticker so that it doesn't get damaged.
  5. Motorola Q Global Camera Replacement: passo 5, imagem 1 %32 Motorola Q Global Camera Replacement: passo 5, imagem 2 %32
    • Remove the six labeled screws with a T5 Torx Screwdriver.
  6. Motorola Q Global Camera Replacement: passo 6, imagem 1 %32
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Camera Replacement: passo 7, imagem 1 %32 Motorola Q Global Camera Replacement: passo 7, imagem 2 %32
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Motorola Q Global Camera Replacement: passo 8, imagem 1 %32 Motorola Q Global Camera Replacement: passo 8, imagem 2 %32
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Motorola Q Global Camera Replacement: passo 9, imagem 1 %32
    • Use the plastic opening tool to lift the camera from the phone.
  10. Motorola Q Global Camera Replacement: passo 10, imagem 1 %32
    • The new camera can now be attached to the motherboard.
Conclusão
Equipe
Cal Poly, Team 6-31, Regan Fall 2012 Membro de Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 678
