Ir para o conteúdo principal
Motorola Photon 4G MB855 Speaker Replacement
O que você precisa
  1. Motorola Photon 4G MB855 Speaker Replacement, Removing the Back Cover: passo 1, imagem 1 %32 Motorola Photon 4G MB855 Speaker Replacement, Removing the Back Cover: passo 1, imagem 2 %32
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Speaker Replacement, Removing the Battery: passo 2, imagem 1 %32 Motorola Photon 4G MB855 Speaker Replacement, Removing the Battery: passo 2, imagem 2 %32
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Speaker Replacement, Removing Screw Covers: passo 3, imagem 1 %32 Motorola Photon 4G MB855 Speaker Replacement, Removing Screw Covers: passo 3, imagem 2 %32 Motorola Photon 4G MB855 Speaker Replacement, Removing Screw Covers: passo 3, imagem 3 %32
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Speaker Replacement, Removing the Midframe: passo 4, imagem 1 %32 Motorola Photon 4G MB855 Speaker Replacement, Removing the Midframe: passo 4, imagem 2 %32 Motorola Photon 4G MB855 Speaker Replacement, Removing the Midframe: passo 4, imagem 3 %32
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Speaker Replacement, Locating the Speaker: passo 5, imagem 1 %32
    • Locate the speaker on the back of the midframe.
  6. Motorola Photon 4G MB855 Speaker Replacement, Removing the Speaker: passo 6, imagem 1 %32 Motorola Photon 4G MB855 Speaker Replacement, Removing the Speaker: passo 6, imagem 2 %32
    • The speaker is attached to the midframe with adhesive. Remove carefully.
    • Use the Metal Spudger to get between the speaker and the midframe and slowly lift the speaker upwards.
    • Remove the speaker from the midframe.
Conclusão
Uma outra pessoa concluiu este guia.
Elizabeth Lee
Membro desde: 10/07/14
92 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 8-6, Leahy Fall 2014 Membro de USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Membros
10 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 350
