Ir para o conteúdo principal
Motorola Photon 4G MB855 Motherboard Replacement
O que você precisa
  1. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: passo 1, imagem 1 %32 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: passo 1, imagem 2 %32
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: passo 2, imagem 1 %32 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: passo 2, imagem 2 %32
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: passo 3, imagem 1 %32 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: passo 3, imagem 2 %32 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: passo 3, imagem 3 %32
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: passo 4, imagem 1 %32 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: passo 4, imagem 2 %32 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: passo 4, imagem 3 %32
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: passo 5, imagem 1 %32 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: passo 5, imagem 2 %32 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: passo 5, imagem 3 %32
    • Locate the Display Data Cables
    • Use hands or plastic opening tool to carefully pry off the connectors.
  6. Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: passo 6, imagem 1 %32 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: passo 6, imagem 2 %32 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: passo 6, imagem 3 %32
    • Be careful when removing motherboard. Earpiece is connected with small wires and adhesive. Use thin metal tool to pry off before removing motherboard.
    • Use a plastic opening tool to gently pry off each section of the Motherboard.
    • Use hands to slowly and carefully remove the motherboard from the front panel assembly.
Conclusão
4 outras pessoas executaram este guia.
Eddie Krause
Membro desde: 10/07/14
260 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-6, Leahy Fall 2014 Membro de USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 1,321
