Ir para o conteúdo principal
Motorola Photon 4G MB855 Midframe Replacement
O que você precisa
  1. Motorola Photon 4G MB855 Midframe Replacement, Removing the Back Cover: passo 1, imagem 1 %32 Motorola Photon 4G MB855 Midframe Replacement, Removing the Back Cover: passo 1, imagem 2 %32
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Midframe Replacement, Removing the Battery: passo 2, imagem 1 %32 Motorola Photon 4G MB855 Midframe Replacement, Removing the Battery: passo 2, imagem 2 %32
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Midframe Replacement, Removing Screw Covers: passo 3, imagem 1 %32 Motorola Photon 4G MB855 Midframe Replacement, Removing Screw Covers: passo 3, imagem 2 %32 Motorola Photon 4G MB855 Midframe Replacement, Removing Screw Covers: passo 3, imagem 3 %32
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Midframe Replacement, Removing the Midframe: passo 4, imagem 1 %32 Motorola Photon 4G MB855 Midframe Replacement, Removing the Midframe: passo 4, imagem 2 %32 Motorola Photon 4G MB855 Midframe Replacement, Removing the Midframe: passo 4, imagem 3 %32
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Eddie Krause
Membro desde: 10/07/14
260 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-6, Leahy Fall 2014 Membro de USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 321
