Ir para o conteúdo principal
Motorola Photon 4G MB855 Battery Replacement
O que você precisa
  1. Motorola Photon 4G MB855 Battery Replacement, Removing the Back Cover: passo 1, imagem 1 %32 Motorola Photon 4G MB855 Battery Replacement, Removing the Back Cover: passo 1, imagem 2 %32
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Battery Replacement, Removing the Battery: passo 2, imagem 1 %32 Motorola Photon 4G MB855 Battery Replacement, Removing the Battery: passo 2, imagem 2 %32
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 8-6, Leahy Fall 2014 Membro de USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,306
