Introdução
Pre-req only guide on disconnecting the battery on your Moto Z2 Force for futher dissassembly.
O que você precisa
Use a pair of tweezers to remove the two black pieces of tape securing the battery.
Use an opening pick to pry up the small black bracket covering the battery connector. It is secured with a small bit of adhesive.
Use a pair of tweezers or your fingers to remove the bracket.
Use a spudger to pry up and disconnect the battery connector.
Quase terminado!
Conclusão
