Pular para o conteúdo principal
Introdução
Though not necessary, it is recommended that the battery is removed before removing the rear camera, simply for safety reasons.
    • Your Moto X4 may not be water resistant after reassembly.
    • Before beginning the disassembly of your Moto X4, discharge the battery below 25%. A charged lithium-ion battery can catch fire or explode if accidentally punctured.
    • Use an iOpener or a heat gun to heat up all four edges of the display until it's slightly too hot to touch, in order to soften the adhesive holding it in place.
    • Slide a thin pry tool such as an opening pick or playing card underneath the edge of the display, and work it carefully around the entire perimeter of the phone to slice through the adhesive.
    • Don't insert your tool more than a few millimeters, or you may damage the display cables on the right edge.
    • Open the display from the left edge, and swing it to the right. Don't try to fully detach it yet.
    • When your repair is complete, thoroughly remove all the old adhesive surrounding the display, and clean the adhered surfaces with isopropyl alcohol and a lint-free cloth. Install your new display with a strong double-sided tape, such as Tesa 61395.
  1. Insert the spudger under the black tab by the top connector, then pry it up. Grab the cable and gently disconnect the screen from the rest of the Moto X4. Grab the cable and gently disconnect the screen from the rest of the Moto X4.
    • Insert the spudger under the black tab by the top connector, then pry it up.
    • Grab the cable and gently disconnect the screen from the rest of the Moto X4.
  2. Insert the spudger under the black tab by the bottom connector, then pry it up. Grab the cable and gently disconnect the screen from the rest of the Moto X4. Grab the cable and gently disconnect the screen from the rest of the Moto X4.
    • Insert the spudger under the black tab by the bottom connector, then pry it up.
  3. Remove the sim card tray by inserting a sim card remover into the small hole on the top edge of the device. Once sim tray is unlatched, simply pull it out. The Moto X4 comes with a sim removal tool in the box, but this can be substituted for a straightened paper clip.
    • Remove the sim card tray by inserting a sim card remover into the small hole on the top edge of the device.
    • Once sim tray is unlatched, simply pull it out.
    • The Moto X4 comes with a sim removal tool in the box, but this can be substituted for a straightened paper clip.
  4. Remove the nine 3mm T5 Torx screws securing the silver plate to the device. Remove the eleven 2mm T4 Torx screws securing the plate to the device. Remove the eleven 2mm T4 Torx screws securing the plate to the device.
    • Remove the nine 3mm T5 Torx screws securing the silver plate to the device.
    • Remove the eleven 2mm T4 Torx screws securing the plate to the device.
  5. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Use the flat end of a spudger to pry up the silver plate from both sides. Use the flat end of a spudger to pry up the silver plate from both sides. Use the flat end of a spudger to pry up the silver plate from both sides.
    • Use the flat end of a spudger to pry up the silver plate from both sides.
  7. Use a pair of tweezers to gently lift the battery connector wire. Use a pair of tweezers to gently lift the battery connector wire.
    • Use a pair of tweezers to gently lift the battery connector wire.
  8. Remove the 20mm screw that is holding in the motherboard with a T3 driver.
    • Remove the 20mm screw that is holding in the motherboard with a T3 driver.
  9. Use flat edge of the spudger to pry up the two blue connectors near the top of the device. Use flat edge of the spudger to pry up the two blue connectors near the top of the device. Use flat edge of the spudger to pry up the two blue connectors near the top of the device.
    • Use flat edge of the spudger to pry up the two blue connectors near the top of the device.
  10. Use flat side of spudger to pry up connector near the bottom of the device. Use flat side of spudger to pry up connector near the bottom of the device.
    • Use flat side of spudger to pry up connector near the bottom of the device.
  11. Using a pair of tweezers disconnect the vibrating motors connector near the bottom of the device. Using a pair of tweezers disconnect the vibrating motors connector near the bottom of the device. Using a pair of tweezers disconnect the vibrating motors connector near the bottom of the device.
    • Using a pair of tweezers disconnect the vibrating motors connector near the bottom of the device.
  12. Carefully pry up the motherboard using the spudger. The previously disconnected wires may have to be held back in order to easily remove the motherboard.
    • Carefully pry up the motherboard using the spudger.
    • The previously disconnected wires may have to be held back in order to easily remove the motherboard.
  13. Using a T3 Torx screwdriver,  remove both  1cm  screws. To do this, insert the screwdriver into the head of the screw, then turn counter-clockwise. Using a T3 Torx screwdriver,  remove both  1cm  screws. To do this, insert the screwdriver into the head of the screw, then turn counter-clockwise.
    • Using a T3 Torx screwdriver, remove both 1cm screws. To do this, insert the screwdriver into the head of the screw, then turn counter-clockwise.
  14. Use the tweezers to gently lift the rear camera  up and out of your Moto X4. Use the tweezers to gently lift the rear camera  up and out of your Moto X4.
    • Use the tweezers to gently lift the rear camera up and out of your Moto X4.
Conclusão
2 outras pessoas concluíram este guia.
Brian Buchanan
Membro desde: 24-01-2018
679 reputação
4 Guias de autoria
Equipe
Cal Poly, Team S18-G4, Livingston Winter 2018 Membro de Cal Poly, Team S18-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G4
4 Membros
13 Guias de autoria
I'm up based anyone know where I can get a replacement camera
Ashley Fall - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 88
Todo: 1,363
