Introdução
This is pre-requisite only guide for opening the Moto X4 to perform other repairs.
O que você precisa
Heat an iOpener and apply it to the left edge of the phone for two minutes.
As you wait, take note of the the following areas:
Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
Apply a suction cup to the screen, as close to the heated edge as possible.
Pull on the suction cup with strong, steady force to create a gap in the seam.
Insert the point of an opening pick into the gap.
Slide the opening pick along the edge to slice through the adhesive.
Leave an opening pick in the seam to prevent the adhesive from re-sealing.
Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
Use tweezers to carefully slide the display cable out of the ZIF socket.
