Introdução
Follow this guide to remove a cracked or broken screen for the Moto X4.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
As part of the procedure, you will have to transfer the fingerprint sensor from your broken screen to the replacement part.
O que você precisa
Heat an iOpener and apply it to the left edge of the phone for two minutes.
As you wait, take note of the the following areas:
Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
Apply a suction cup to the screen, as close to the heated edge as possible.
Pull on the suction cup with strong, steady force to create a gap in the seam.
Insert the point of an opening pick into the gap.
On the left side it is a very thin strip of adhesive—but there are other places where there is alot more adhesive—If you look at the black part of the new adhesive-if you have the phone specific adhesive thing—you will get an idea what you might be trying to push through at any given spot on the phone. orient the new one over the old screen to line up holes etc-to understand where the adhesive is.
Slide the opening pick along the edge to slice through the adhesive.
Leave an opening pick in the seam to prevent the adhesive from re-sealing.
Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
Use tweezers to carefully slide the display cable out of the ZIF socket.
Remove the screen.
I found that the subsequent steps will be smoother if you spend a little time at this point cleaning out the old adhesive pieces. The picture above shows pulling off some of the old glue strips, but the bullet points don’t mention it. Removing the mid-frame and other steps is easier if the old adhesive has been cleaned out.
Good point Gordon! I’ve adjusted the wording on the second bullet to point people in the right direction.
I’d already used the free form adhesives to glue the screen back on before I realized the kit came with a ready-to-go adhesive sheet. It’d be nice if this were mentioned (or pictured) here.
The provided replacement screen does not have the black plastic film w/ 5 x 3 holes in it
photo to illustrate: top is replacement screen. Bottom is old screen, w/ black film w/ holes
Not sure how to proceed here.
Apply a heated iOpener to the fingerprint sensor for one minute to soften the adhesive gasket.
Slide the point of a spudger under the fingerprint sensor cable and gently pry to loosen the cable from the screen.
Use the flat edge of a spudger to push the grille from the front side of the screen to loosen it from its recess.
Remove the grille.
If your replacement part did not come with a lower microphone gasket, use tweezers to carefully peel it from your old screen and transfer it to your replacement part.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
23 outras pessoas executaram este guia.
8 comentários
This guide really only covers screen removal, and should detail replacing the screen as advertised. Here are a few more steps that should be added:
1. Transferring old hardware to the new screen (seals, filters, fingerprint sensor, & the grey carbon mat.
2. Cleaning up old adhesive.
3. Applying new adhesive, whether it’s the one-piece that ifixit carries (recommended), or Tesa tape.
4. Installing the new display assembly
Is it possible to remove and replace only the glass? Can I do that without removing the whole LCD screen and avoid disconnecting/reconnecting wires?
Hi Drew,
I haven’t tried, but I think it is possible to do a glass-only repair for this LCD screen, as long as you have the necessary tools and bonding adhesives. You would still have to deal with the fingerprint sensor, which is sealed onto the glass.
I noticed the fingerprint sensor not being quite as low on the right edge after this. Also, I think it has a bit of “give” now when I press on it with a thumbnail. If the tips of my thumbs weren't so dry right now I might not have noticed, though.
Hey Chris,
Did you add adhesive to the fingerprint sensor, if you didn't add some adhesive it may have some play, as most things need to be glued in place, and you could have forgotten to add some new adhesive.
I just finished following your guide and mostly satisfied. Somehow my fingerprint sensor doesn’t work but <shrugs> If I loose that convenience for a time, then I still payed less and got experience. Now, for the constructive criticism. YOU NEED a re-assembly guide. We’re not all at the level you guys are and it took a lot more work for me to put things back together as I had to flip things around and watch a few other videos to see steps I missed. You need a guide because you some of the items you’re supposed to use are not mentioned here because they’re not used until you re-assemble it. Please add it to this guide (for future people) unless you’re going to stop selling this kit, then just add it to the other kits. It would be a great help.
Agree completely with this statement and others above. Please do re-assembly. It’s a few more photos and it makes sure you did not miss anything as this user said. At this point, in my replacement, I do not know where to start with the adhesive, etc.
Andrea -
What is the 'carbon mat'?? Is it the black backing with 15 holes that was on the inside of original screen? I'll transfer this and hope that's right. And YES . . . We definitely need ReInstall directions. I would really like to know exactly how to use the pre cut adhesive, or the Tesa tape, if needed... which I think I will. I lost the speaker screen and had to pull one from another phone. But as for other holes... I would feel much better k king I'm doing it right. It really dies no good to perfectly remove the old screen. . . If you screw up installing the new one. All in all - I'm so very Thankful this site dies exist and you guts are excellent. There's still room to grow to reach perfection ( wink**) but helping to keep the power in our hands, is priceless. I love learning and always like to know what I'm using, how it works, and how to fix it. The automotive world is pushing us further away each year. Thank you and good luck everyone.
Complete novice. Getting old screen off was time consuming! I was too afraid of ruining something by overheating. Spent many hours trying to use iopener, afraid to risk bursting it in microwave. Read many comments in the iopener use guide; a guy said to get the screen temp up to 120-130F. Saw several youtube videos esp. Witrig one on replacing Moto x4 screen, they used heat gun 100C=212F so I got braver and put my phone on kitchen hot plate. Measured temperature by laying stem of candy thermometer on the surface. When hot plate got to 150-160F I finally got a pick under phone ‘s glass edge & got the screen off. Hot plate temp. not stable, guess phone was there a few minutes. May have damaged display but was replacing it anyway. Now new screen installed everything working properly! I’m not sure I was using the suction cup when I finally was able to push the pick under the edge.
Nahariyah Mosenkis - Responder
